INFORMAÇÕES TÉCNICAS DO MX-3
Mensagempor Paulo_mx3 » Qui Ago 10, 2006 9:26 am
SPECIFICATIONS:
ENGINE MX-3 RS (1992-1993) MX-3 RS (1994-1998) MX-3 GS (1992-1996)
Type Inline 4-cylinder Inline 4-cylinder V6
Valve gear SOHC 16-valve DOHC 16-valve DOHC 24-valve
Displacement 1597 cc 1598 cc 1844 cc (112.5 cu.in.)
Bore and Stroke 78 x 84 mm 78 x 84 mm 75 x 70 mm
Compression Ratio 9.0 : 1 9.0 : 1 9.2 : 1
Horsepower
SAE net 88 @ 5000 rpm 105 @ 6200 rpm 128 @ 6500 rpm
Torque, SAE net
lb.-ft. 98 @ 4000 rpm 100 @ 3600 rpm 115 @ 4500 rpm
Fuel System Multi-port, EFI Multi-port, EFI Multi-port, EFI
Fuel Regular unleaded Regular unleaded Regular unleaded
DRIVETRAIN ==========================================
Type Front Engine / front drive
Transmission 5-speed manual with overdrive Optional: 4-Speed electronically controlled automatic with overdrive and hold model
Ratios: MT RS AT RS MT GS AT GS
1st 3.42 2.80 3.31 2.80
2nd 1.84 1.54 1.83 1.54
3rd 1.29 1.00 1.31 1.00
4th 0.92 0.70 1.03 0.70
5th 0.73 - 0.80 -
Final Drive 4.11 3.83 4.39 4.06
ELECTRICAL SYSTEM ===================================
Type 12 Volt
Battery Maintenance Free 48 amp/hr (RS); 43 amp/hr (GS)
Alternator 70 amp (RS); 90 amp (GS)
Cold Cranking Capacity 356 amp (RS); 521 amp (GS)
Ignition System Breakerless Electronic
CHASSIS =============================================
Frame Unit body (Monocoque)
Front Suspension Independent, strut type with coil springs and stabilizer bar
Rear Suspension Independent, strut type with coil springs, Twin Trapezoidal Links
(TTL), stabilizer bar, and lateral reinforcement rod.
Steering Rack-and-pinion type with engine-rpm-sensing variable power
assist
Steering Ratio 17.0:1 (RS); 15.0:1 (GS)
Steering Wheel Turns 3.1 (RS); 2.7 (GS) (lock to lock)
Turning Circle, curb to curb 10.0 m (32.8 ft.)
Brakes Power-assisted with dual diagonal hydraulic circuits Ventilated
front discs 236 mm (RS), 257 mm (GS) Rear drums 200 mm
(RS), 252 mm (GS) Optional on GS MT: Anti-lock Brake System
(ABS)
Wheels 5.5 JJ - 14 inch steel wheels 2/full wheel covers (RS) 6.0 JJ - 15
inch alloy wheels (GS)
Tires Steel belted radial tires All-season P185/65 R14 85S (RS), P205/55
R15 87V (GS)
Curb Weight RS MT/AT: 1095 kg (2414 lbs)/ 1125 kg (2480 lbs) GS MT/AT:
1171 kg (2582 lbs)/ 1194 kg (2632 lbs)
CAPACITIES ===========================================
Seating 4 passengers
Engine Oil 3.4 litres (RS); 4.8 litres (GS)
Coolant 6.0 litres (RS); 7.5 litres (GS)
Washer Fluid Tank 5.0 litres
Fuel Tank 50 litres
EXTERNAL DIMENSIONS MM (in.) ==========================
Wheelbase 2455 mm
Track (Fr/Rr) 1460 mm / 1465 mm
Overall Length 4208 mm
Overall Width 1695 mm
Overall Height 1320 mm
INTERNALl DIMENSIONS MM (in.) ==========================
Headroom (Fr/Rr) 969 mm / 860 mm
(with sunroof) 952 mm / 860 mm
Legroom (Fr/Rr) 1082 mm / 790 mm
Shoulder Room (Fr/Rr) 1327 mm / 1224 mm
Hiproom (Fr/Rr) 1299 mm / 1148 mm
EPA Passenger Volume 15.4 cu ft. w/rear seat up, 36.6 cu ft. w/rear seat down
ESTIMATED PERFORMANCE DATA =========================
MX-3 RS MX-3 GS
Acceleration (0-100 km/h) 9.8 seconds 8.5 seconds
Acceleration (0-400M km/h) MT: 16.8, AT: 17.2 MT: 15.7, AT: 16.6
Acceleration (0-1000M km/h) MT: 29.7, AT: 32.0 MT: 28.8, AT: 30.2
Top Speed (km/h) MT: 180, AT: 170 MT: 199, AT: 181
Coefficient of Drag (Cd) 0.32 0.31
Weight Distribution 63 / 37 65 / 35
This is what I got so far. More things on there way. As of now I am working on more material for the page and I am only one. Hope you like it. ENJOY!!!
Main Hall
Paulo_mx3
