[How To] Mudar a iluminação do painel do ar
Mensagempor David Farina » Qui Out 08, 2009 9:34 am
how-to copiado na íntegra do mx-3.com, postado pelo ovendenk
link fonte: http://www.mx-3.com/phpBB3/viewtopic.php?f=28&t=54423
se alguém fizer e ficar legal, com certeza será gratificante para o ovendenk ver um post seu de agradecimento lá, e, com fotos ;)
first off i need to explain how the panel is made by mazda to clarify future steps in the how-to. the panel seems to be a clear piece of plastic that has multiple layers of paint on it. first mazda paints the entire panel black except for the graphics. then over each graphic, they paint white so you can see it during the day. lastly they painted a green layer to give it its color at night. we need to get rid of that green layer!!!
to begin you need to carefully peel off the section of the panel with the graphics. it is flexible , but you do not want to scratch it or you will screw it all up.
now you need to remove the old adhesive to make sure you have a clean and even surface to work with. varsol works great and it won’t melt the paint. zippo fluid would probably work as well, but never tried it. here's what it looks like after it's been cleaned.
here’s the tricky part. you need to strategically melt the green paint off using lacquer thinner (water based, so it will evaporate). problem is that it will also melt the white and black layers. if you melt the black layer at all, you’ll need a new panel and start over because the black layer is what defines the graphics. trick is to use a small instrument like a Q-tip or smaller if possible. also you need to make sure that you don’t over saturate the Q-tip with thinner because it melts the paint quickly. have a tissue close by to wipe up and drops or excess thinner.
now that you have gotten rid of all the green on each individual graphic, you’ve probably melted some white here or there (and hopefully no black). to fix this i used tissue paper and glued it across the entire panel to simulate the white paint layer.
now you just need to make a light filter of some sort. you can either put a colored sleeve on the bulb or (like i did) color another piece of tissue paper and glue it on top of the white tissue paper you already glued or both for best results.
i’m sure this would also work on the gauges if you want.
*** remember: any time you scratch or melt black paint, light will shine through and show your mistake***
here's a before and after shot.
Re: [How To] Mudar a iluminação do painel do ar
Mensagempor David Farina » Qui Out 08, 2009 9:37 am
Notem que não fica perfeito hein ! ao remover a pintura original, o rapaz danificou a peça dele, isto está claramente visível nas duas últimas fotos (original / modificado)...
perdeu-se muitos detalhes...
então, façam por conta e risco :p
Mensagempor mx3black » Qui Out 08, 2009 10:22 am
Já desisti, a chance de dar uma M, é bem grande, além do mais se não remover essa tinta direitinho os desenhos vão ficar falhados e tortos.
Será que só de colocar um LED azul já não dá um efeito maneiro ?
Mensagempor David Farina » Qui Out 08, 2009 10:54 am
entao, ae soh testando...
eu creio que, por ser verde, ao colocar um led azul de superbrilho, vc consiga uma iluminação quase azul :)
mas, tem q comprar um e testar :(
Mensagempor Miguelitto » Qui Out 08, 2009 1:48 pm
intaum galera....., eu coloqui um led azul naquele botão de controlar a intencidade da iluminação...
ficou super bom, quero fazer isso no botão do minha, do desenbaçador e no controle do ar(mas infelizmente soh tinha um led)....
Galera apenas lembrarn q se for por led, tem q por as resistencias adequadas hein...., eu queimei um led pq eu fui testar a corrente, e tava sem elas, hehe....
FArina quando meu carro voltar do salão de beleza, eu vo tentar dai faço um Raúl Maneiro, hehe......
Será q pra tirar aqueles pininhos das pontas das alavancas eh soh puxar?!!?
Mensagempor David Farina » Qui Out 08, 2009 2:19 pm
eu acredito q sim, miguelitto, normalmente eles são apenas encaixados assim...
acho pouco provavel que se tenha que empurrar para cima ao invéz de puxar os pininhos para tirar eles... creio que, se fosse algo fora do convencional, o ovendenk teria avisado no tuto :)
Mensagempor Miguelitto » Qui Out 08, 2009 2:22 pm
foi isso q pensei tb....
eu desmontei o da montana, e eh asim tb... eh soh puxar com força q sai, hehe......
to ancioso pra testar, hehe...
Mensagempor tomazela » Qui Out 08, 2009 6:24 pm
Puts, mesmo que tivesse ficado perfeito , o que nao ficou , eu acho bem mais legal a cor verde =)
tomazela
Registro: 23/09/2009
Mensagempor Aropeli » Ter Jan 11, 2011 8:06 pm
Pessoal as imagens sumiram
Mensagempor David Farina » Ter Jan 11, 2011 9:08 pm
eh, eu ví...
como na epoca eu n hospedei elas em algum host, perderam-se...
agora soh qdo alguem achar algum local onde esse tuto foi copiado...
Mensagempor Paulo » Ter Jan 11, 2011 9:31 pm
Amigos, NÃO FAÇAM O QUE DIZ O TOPICO, NÃO REMOVAM A TINTA VERDE, VCS CORREM O RISCO DE ESTRAGAR O PAINEL, UTILIZEM APENAS LAMPADA LED T10 AZUL E VERMELHA. Desculpem pelas letras em cx alta mas foi para chamar a atenção e evitar danos aos´muitos painéis de MX por aí.
A verdade é que a luz do led, de alto brilho, passa tranquilamente pelo verde, e do outro lado vai acender azul. Ela não passará pelo vermelho daí a necessidade de usar led vermelho também. No meu carro eu coloquei duas lampadas led T10 azul, daquelas utilizadas em faróis e uma carreira de led vermelho, que pode ser substituído por uma lampada led T10 vermelha. Montei tudo(lampadas led) atrás do painel do ar, retirando o plástico branco existente na parte interna do encaixe do painel e o resultado foi ótimo acende em azul onde era verda e em vermelho o que era vermelho, sem erro.
Mensagempor BSunBest » Ter Jan 11, 2011 10:03 pm
E para o painel ficar com aquela iluminação branca, que fica bem mais bonito. Como faz ?
Só colocar leds brancos e já dá o efeito ?
Mensagempor Paulo » Ter Jan 11, 2011 10:09 pm
Eu só fiz o teste com o azul e o vermelho pq coloquei o Glow (acende azul) no painel. Só fazendo o teste para ver.
Mensagempor lucasmessias » Sáb Ago 06, 2011 9:15 am
galera algum consegue as fotos denovo ...queria ver o resultado
lucasmessias
Registro: 03/01/2011
Mensagempor deepbluemx3 » Sáb Ago 06, 2011 11:22 am
-esse tutorial não vale a pena fazer no mx, porque ele usa tinnerpra descolorir as figuras e acaba destruindo-as!
Use leds azuis SMD que faz o mesmo efeito sem destruir o paonel do ar...
Veja na área de membros o mx do AndersonR, ou o meu, pra vc ver como fica, no tópico do Ander tem até o How-To dos botões... :D
Retornar para How-To
